Results 1 to 9 of 9
Thread: LS + turbo, later swap in gsr
    Heres the situation. I have a 96 Integra ls with 88K miles on it. I'm wanting to put a turbo on it for now and then in a year, or when it breaks which ever comes first, put a gsr motor in it. So which turbo kit would be easiest to change from an ls motor to gsr motor. Or am I just wasting my time by trying to do the turbo first.
    why not just keep the boosted ls motor? b18c has higher compression.....not as boost friendly as b18b. i'm keeping my b18a1 & just building it for more boost.
    youre engine should last more than a year with only 88k on it
    I have to agree with the above stated comment. Because of the LS's lower compression its alot more boost friendly. Instead of getting a B18c in a year, you should consider saving the money and rebuilding your B18b1 (rods, pistons, etc) That setup will run rings around the stock c1 motor.
    Happy hunting
    I just wanted to say I agree. Fix your Ls engine! Put turbo on it and be happy. :cool:
    yah build the ls for turbo ls but jus for the record i love my turbo gsr hehehe
    You dont need no stinkin GSR! If your going to invest in a turbo the LS is a much better engine for it anyway: lower compression, cheaper to buy/replace/rebuild, ect. 88k is nothing on one of those and it should be able to handle up to 9-10 psi of boost stock. Instead of wasting money on a GSR engine later sink that 4 grand into rebuilding the LS engine to handle higher boost and youll have yourself a sweet fuckin ride!
    Thanks to everyone for your suggestions. Seems everyone is telling me the same thing, so i probably won't swap out the engine. But let me ask one more question? Somewhere else on this site someone wrote about keeping the ls bottom and putting a v-tec head on. Could anybody tell me more about this, or should I not even bother with the engine until after I put the turbo on it?
    if you want to go ls/vtec, from what i hear it's not really a good idea to boost it. if built correctly though, it's s'posed to be a pretty powerful thing (low end torque from ls, high end hp from vtec). i always see ppl saying that if you build an ls/vtec, you should just push the n/a envelope. personally though, like i said, i'd stick with a boosted ls.
