Thread: BOOMSLANG ECU JUMPER HARNESSES
    Default BOOMSLANG ECU JUMPER HARNESSES
    Looking to installed a chipped OBD1 ECU or any other ECU that doesn't match up with the plugs on your stock Honda dash harness? Check out our selection of ECU Jumper Harnesses. All harnesses are professionally manufactured by boomslang fabrication from brand new OEM style connectors and high strength green insulated wire. All harnesses feature a full one year manufacturer's warranty against defects. You will not find a higher quality jumper harness anywhere!
    OBD0 to OBD1 Jumper Harness
    Use this harness to install any OBD1 civic / integra ECU into an 88-91 civic / CRX EF chassis. Comes complete with 4 wire o2, IAB, VTEC, and Knock sensor pigtails for a painless conversion to OBD1. *ALWAYS IN STOCK*
    OBD2A to OBD1 Jumper Harness
    Use this harness to install any OBD1 civic / integra ECU into a 96-98 civic, 96-99 integra, 96-01 prelude, or 96-97 accord. This will allow for a painless plug-n-play installation of a chipped OBD1 ECU. *ALWAYS IN STOCK*
    OBD2B to OBD1 Jumper Harness
    Use this harness to install any OBD1 civic / integra ECU into a 99-00 civic, 00-01 integra, or 98-02 accord. Allows painless, plug-n-play of a chipped OBD1 ECU. * ALWAYS IN STOCK*
    Questions? Please don't hesitate to give us a call (209)324-9880 or email [email protected]
    Shop our selection online 24/7 HERE
    www.HAMotorsports.com 209.324.9880 - Your Honda Engine Management Specialists!
    Custom built chipped Honda / Acura computer systems! Hondata, Neptune, Crome, Jumper Harnesses, Chipping kits, and more!
    Nothing runs a Honda engine better than a Honda ECU!
    Now in stock is the OBD2B to OBD2A harness and the OBD2A to OBD2B harness. These will allow simple plug and play installation of alternate OBD2 ECU's in your car.
    Hi..
    I got a 96 323baF with a KLZE, but with a VAF and ECU from a KFZE. I tried to put a epromed KL-31 ECU into the cars system, but it hits a fuse and will not start up. Somebody knows what to do?
    -Knudsen, Denmark.
    possibly a stupid question and if it was feasible it probably but what about using a 4agze supercharged mr2 ecu and wire harnesses as a solution for engine control on a low boost 7afte
