Results 1 to 1 of 1
Thread: "How To..." Thread index.
    Default "How To..." Thread index.
    This is an index of all the useful "how to" threads in the Accord forum. This list should continue to grow as members create useful (and detailed!) threads. If you know of a thread that you think belongs here, PM me with the link! If I (and the other mods) find it acceptable, it'll be added. Keep in mind, for a thread to be added to this list, it has to be clearly written. Include all tools needed, cover all steps, and try to warn of common mistakes. Pictures are always a plus as well! I will try to keep this list in alphabetical order as it grows.
    NOTE: To have an article added to this list, PLEASE titile it "HOW TO... *****" That will help in determining what should be considered.
    Axle replacement
    Brake bleeding
    Camshaft replacement
    Clear SRS light
    Clutch master and slave cylinders
    Cooling system Electrolysis
    Fuel Filter Replacement
    Ignition system troubleshooting
    Rotor over hub replacement
    Steering Wheel wobble diagnosis
    Stripped oil pan bolt repair
    Timing belt replacement
    Tube seal replacement (if there's oil on your plug wires)
    Valve adjustment
    VSS
    Water in trunk
    7th Generation Accord bumper and headlight removal
