Forum Home
Photo Gallery
AIM Chat
Go Back   Hondahookup.com > Car Specific > Civic, CR-X, Del Sol
Register Gallery Product Reviews HHU Store Forum Rules Gallery Videos Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-06-2009, 11:55 PM   #1
BimmerTech
Default ATF for power steering fluid?
Just found the manual and answered my question.
is there a cheap alternative to OEM Honda steering fluid?
ie. power steering fluid from Lordco/Napa
BimmerTech is offline
Old 11-07-2009, 02:02 PM   #2
omer
Images: 3
Using ATF instead of power steering fluid leads to be a leakage. This may damage the system for a long term.
__________________
94 USDM Civic EX.
omer is offline
Old 11-07-2009, 02:59 PM   #3
BimmerTech
right, I discovered that after a bit of reading.
my question now is........
can generic/aftermarket P/S fluid be used or does it specifically need to be Honda OEM P/S fluid?
Old 11-07-2009, 07:45 PM   #4
Enigma
REAPER
Enigma's Avatar
you can just use ATF, but its the same price as power steering fluid... and no you dont need fancy honda power steering fluid
__________________
Enigma is online now
Old 11-07-2009, 07:53 PM   #5
jcdimvic
the way that i look at it is that honda spent millions and maybe billions in engineering, why not just put in what they say works? If they wanted ATF in it then they would have said ATF or whatever, they specify that honda genuine powersteering fluid only. thats my 2 cents, i kno folks who run ATF, Its just not me
jcdimvic is offline
Old 11-08-2009, 10:20 AM   #6
AceCombat
Because Honda wants to make back their millions and millions of dollars by selling you the 30 dollar bottle of Honda Power steering fluid which is really just ATF fluid in a different bottle. Same with the goofballs who put nitrogen in their tires and think they will get better gas milage and less tire wear. I love the look on their faces when I tell them they could have had almost pure nitrogen for free. Since the air we breathe is about 78% nitrogen.
AceCombat is offline
Old 11-08-2009, 02:17 PM   #7
omer
Images: 3
Previous owner of my car used ATF instead of PSF.
It leaks slightly at the both end of rack then I must add some oil in every month.
And I think it causes minor pressure loose for low speed operation.
I'm replaced all the seal and washers on power steering system and refilled it with Honda psf. There is no leak at least two years.
However, In my country, unauthorized Honda services uses third party ATF instead of PSF on every Hondas serviced.
__________________
94 USDM Civic EX.
omer is offline
Old 11-08-2009, 10:44 PM   #8
AceCombat
1995 Honda Civic DX Coupe 467000kms on it and has had ATF in it for at least 10 of those years. Previous owner did it when the original pump dies from get this " leaking" I just looked and there are no leaks or wets pots anywhere on the power steering pump or the rack. You decide, I will stick with the ATF fluid as its about 25 dollars cheaper.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
