Forum Home
Photo Gallery
AIM Chat
Go Back   Hondahookup.com > Marketplace > Vendor Classifieds > Styling Interior & Exterior
Register Gallery Product Reviews HHU Store Forum Rules Gallery Videos Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 10-21-2009, 02:36 PM   #1
speedracer18
Authorized Vendor
speedracer18's Avatar
Default JDM parts inside long list of items
INTERIOR
92-95 Honda Civic
EG Audio Console (black / grey / blue)
EG Coin Pocket
96-00 Honda Civic
EK9 Armrest Delete (Black)
Armrest Delete Bracket
EK9 Roof Console
EK9 Sunglass Holder
EK9 CTR Carbon Gauge Cluster Trim
EK9 CTR Shift Boot
EK9 Air Bag Block Off Tray (Light Grey)
EK9 Air Bag Block Off Tray (Dark Grey)
06-10 Honda Civic
FD2 Shift knob 6MT
FD2 locking collar
FD2 Shift boot
FD2 Engine Start Button
FD2 Engine Start Button Housing
FD2 Hazard button
FD2 Lower Gauge Cluster
FD2 Upper Gauge Cluster
FD2 Steering wheel SRS not included
FD2 Steering wheel trim
FD2 Type R front seat assy. (Special order assembly required.) L or R
FD2 Type R rear seat assy. (Special order assembly required.)
FD2 Type R door panel. Front. (Special order assembly required.) L or R
FD2 Type R door panel. Rear (Special order assembly required.) L or R
94-01 Acura Integra
DC2 Armrest Delete (Black)
DC2 ITR Blank Key
DC2 ITR Shifter
DC2 ITR Titanium Shift Knob
DC2 Air Bag Block Off Tray (Black)
DC2 ITR Clock Block Out
DC2 Carbon Fiber Gauge Cluster Trim
DC2 ITR Access Panel (SRS Momo Wheel)
DC2 ITR Horn Button (Non SRS Momo Wheel)
DC2 ITR Center Console Plaque
DC2 ITR Center Console Plaque (98 Spec)
DC2 ITR Shift Boot
DC2 Fog Lamp Switch
02-06 Acura RSX / 02-05 Honda Civic Si
DC5 / EP3 Type R Shift Knob (6 speed)
Coin Pocket
DC5 Gas Pedal Assembly
DC5 Brake Pedal Assembly
DC5 Clutch Pedal Assembly
DC5 Foot Rest
Generic Fit
DC2 Daul Din Radio Block OUT
DC2 Daul Din Radio Block Out (Carbon Fiber)
JDM Trash Can
Locking Nut for Shift Knob
Replacement Pedal Pad (Clutch/Brake)
NSX Type R horn button
NSX Type S horn button
EG Momo Horn Button "Honda"
EXTERIOR
88-91 Honda Civic / CR-X
EF8 Door Visor Set (CRX w/ US Mirrors)
EF9 Door Visor Set (Hatchback w/ US Mirrors)
92-95 Honda Civic
EG 2dr/3dr Door Visor Set
EG 4dr Door Visor Set
EG SIR Front Lip 2/3/4 door
EG Molding Set
EJ1 Molding Set
EG Sedan Molding Set
EG6 Rear Diffuser
EG8 Ferio rear door garnish
96-00 Honda Civic
EK 2/3 Door Civic Door Visor Set
EK 4 Door Visor Set
EK 96-98 SiR Front Lip w/ Hardware
EK 96-98 CTR Front Lip
EK CTR Rear Lip
EK Hatch / Coupe Molding Set
EK Sedan Molding Set
01-05 Honda Civic
ES 01-05 Civic Sedan Door Visor Set
EP3 Door Visor Set
06-10 Honda Civic
FD2 Civic Door Visor. 4 door only
FD2 wheels (White / gunmetal ) Set of 4 with caps + valve stems
Black Honda lug nuts. 1 pc. Closed end for Honda alloy wheels.
FD2 side skirt set
FD2 Trunk lid. Non Type R. (no holes for spoiler)
FD2 Trunk lid. Type R. (holes for spoiler) SPECIAL ORDER
FD2 Type R rear wing Assy
FD2 Rear bumper conversion assy. (Black)
Bumper cover
Top Bumper Diffuser
Bottom Bumper Diffuser
Bumper Diffuser insert
90-93 Acura Integra
DA6 Front Bumper Extension
DA6 Rear Bumper Extension
DA Molding Set
94-01 Acura Integra
DC2 Door Visor Set
DB8 Door Visor Set
DC2 Champ. White Center Caps
DC2 Gunmetal Center Caps
DC2 JDM Front Bumper (unpainted)
DC2 JDM Hood
DC2 JDM Fender Liners
DC2 JDM Fender (Single side)
DC2 JDM Fender Brackets (pair)
DC2 JDM Radiator Support
DC2 JDM Front Bumper Extension
DC2 JDM Front Bumper Support
DC2 JDM Front Hood Lock
DC2 JDM Front Grill
DC2 JDM ITR Front Lip
DC2 JDM 94-97 SI Vtec Front Lip (US Style front end)
DC2 98+ US ITR Front Lip
DC2 JDM Headlight Hood Seals (pair)
DC2 Euro Rear License Plate Cover
02-05 Acura RSX
DC5 Silver Type R Center Caps (Red H)
DC5 Silver Non Type R Center Caps (Black H)
DC5 02-04 ITR Lip (Front)
DC5 02-04 ITR Lip (Rear)
DC5 Door Visor Set
Other Honda
BB6 Prelude Door Visor
CD6 Accord Door Visor
94-97 Honda Accord rear door garnish
GD3 Fit Door Visor
MOTOR,TRANSMISSION,EXHAUSTS
B series
B-Series Red Valve Cover
B-Series Type R chrome Valve Cover Gasket Set
ITR Oil Cap (not for K series)
B-Series P73 ITR Pistons (81.00mm or 81.25mm)
B-Series P30 B16 Pistons (81.00mm or 81.25mm)
B-Series PCT CTR Pistons (81.00mm or 81.25mm)
B-Series Piston Rings (81.00mm or 81.25mm)
B-Series ITR Intake Cam (96 Spec)
B-Series ITR Exhaust Cam
B-Series CTR Intake Cam
B-Series ITR Intake Valves (Set of 8)
B-Series ITR Intake Valve Springs (Inner) (Set of 8)
B-Series ITR Intake Valve Springs (Outter) (Set of 8)
B-Series ITR Lost Motion Assembly (Each)
B-Series ITR Intake Manifold
Civic Type R Crank Pulley (Single belt)
B-Series JDM ITR 4-1 Header
B-Series JDM Header Upper Heat Shield
B-Series JDM Header Lower Heat Shield
B-Series JDM ITR Header Bracket
2.5" Donut Gasket
Generic 2.5” Collector Flange
B-Series JDM ITR Clutch Disc
B-Series JDM ITR Flywheel
B-Series JDM ITR Pressure Plate
B-Series JDM ITR LSD Unit
B-Series Throw Out Bearing (Hydro Trans)
B-Series ITR 98 Spec 4.7 Final Drive Kit
Counter Shaft
Low gear
Final Ring gear
Distance Collar
Needle Bearings
AC Bracket (B-Series in 92-00 Civic)
B-Series Oil Pump
B-Series Water Pump
B18 Timing Belt (GSR - Type R)
Head Gasket B series VTEC or LS VTEC
B-Series ITR Engine Mount (Rear)
B-Series ITR Engine Mount (Right Side)
B-Series ITR Engine Mount (Left Side)
EK Transmission rear T bracket for B series swaps
EG Transmission rear T bracket for B series swaps
EG, EK, DC2 Front Transmission Torque bracket for B series
B-Series ITR Shift Linkage
JDM 98 Spec ITR Transmission (4.7FD, LSD)
K Series
K-Series Valve Cover (Red)
K-Series ITR Spark Plug Cover
K-Series ITR Intake Manifold Cover
K-Series ITR Dip Stick (Black)
K-Series 5.06 Final Drive kit
Counter Shaft
Final Ring gear
Bearing
Other Honda
H-Series Valve Cover (Red)
H-Series Valve Cover (Blue)
SUSPENSION
DC2 25mm ITR Front Sway Bar
DC2 25mm Front Sway Bar Bushings
DC2 23mm ITR Rear Sway Bar
DC2 23mm ITR Rear Sway Bar Bushings
DC5 ITR Front Sway Bar (Requires Brembo knuckle and LCA)
DC5 ITR Front Sway Bar Bushings
DC5 ITR Rear Sway Bar
DC5 ITR Rear Sway Bar Bushings
EK9 22mm CTR Rear Sway Bar
EK9 22mm CTR Rear Sway Bar Bushings
DC2 ITR Front Strut Tower Bar
EK9 CTR Front Strut Tower Bar
Sway Bar D bracket for EG, EK, DC2 (Pair)
LIGHTING
H4H Headlight Bulbs (Pair)
BB6 Prelude Clear Fog Light Kit
CL9 TSX 02-05 Headlights
DA6 Headlights
DC2 Euro Bumper Lights (US Spec 98+)
DC2 Euro Taillights
DC2 ITR Fog Lamp Covers
DC2 ITR Front End Head Light Covers
DC2 ITR Headlights (Black - Non HID)
DC2 ITR Third Brakelight Block Out (Coupe)
DC5 ITR Headlights (Non HID)
DC5 Side Marker Harness
DC5 Side Marker Socket w/bulb (Pair) EP3, FD2
DC5 Side Markers (Marker Only) Amber or clear
DC5 Side Markers (Complete Kit) Amber or clear
DC5 Yellow Fog Light Kit
EG EK DC Side Marker Wiring Harness (Plug n Play)
EK CTR Headlights 96-98
EK CTR Headlights 99-00
EK9 Yellow Fog Light Kit 99-00 (No Switch)
FD2 Civic 4 door taillight set. JDM trunk only.
FD2 headlight set. Non HID
FD2 Headlight set HID. No bulbs included.
EF, DA Side Marker with bulb and socket
EG, DC2, EK. Side Marker with bulb and socket
S2000 Clear Side Marker (Lens Only)
DC5, EP3, FD1 Clear / Amber Side Marker (Lens Only)
FD2 Side Marker (Lens Only)
EG, DC2 Clear Side Marker (Lens Only)
Side Marker Sockets EG, EK, DC (Pair) including bulb
Side Marker Sockets EP, DC5, FD2 (Pair) including bulb
Side Marker / City Light pig tail harness (pair) All Models
NSX Rear Center Taillight Panel w/H Logo
EMBLEMS & DECALS
S2000 AP1 + AP2 Red “H”. Front or Rear
GD3 “Fit” emblem with red dot
DC2 Red "H" Emblem Front or Rear
DC2 Red “H” Emblem Front (US Front end)
DC2 Silver "H" Emblem Front or Rear
DC2 Euro ITR "HONDA" Emblem
EK9 Red "H" Emblem Front or Rear
EP3 Red "H" Emblem Front (US Grill)
EP3 Red "H" Emblem Rear
EP3 Red “H” Emblem Front (04+ JDM Grill)
CL7 Red “H” Emblem Front. JDM grill
CL7 “Accord” emblem
FD2 Red “H” Emblem Front
FD2 Red “H” Emblem Rear with JDM trunk. (Black Trim)
FD2 Silver “H” Emblem Rear with JDM trunk
FD2 “Type R” rear emblem
FD2 2.0 i-VTEC emblem set
FD2 Red i-VTEC emblem
DC5 02-04 Red "H" Emblem Front
DC5 05+ Red "H" Emblem Front
DC5 Red "H" Emblem Rear
DC5 02-04 Silver "H" Emblem Front
DC5 05+ Silver "H" Emblem Front
DC5 Silver "H" Emblem Rear
DC5 05+ "Type R" Emblem Front
DC5 "Type R" Emblem Rear
DC5 05+ "Type S" Emblem Front
DC5 "Type S" Emblem Rear
DC2 "Integra Type R" Decal Sides
DC2 "Integra Type R" Decal Rear
DC5 "Integra Type R" Decal Sides
EK9 "Civic Type R" Decal Sides
EK9 "Civic Type R" Decal Rear
EP3 "Civic Type R" Decal Sides
EP3 “Type R” Front Emblem 02-03
EP3 “Type R” Front Emblem 04-05
EP3 "Type R" Rear Emblem
DC5 "Integra" Rear Emblem
2.0 Emblem
EG LSD Decal
DC2 "DOHC VTEC" Decal
DC2 ABS Tag
DC2 ABS LSD Tag
DC2 LSD Tag
EF SIR Decal
EK SIR Decal
EK VTI Decal
EP3 UK Flag Emblem
EG EK "DOHC" “VTEC” Decal (4 pc)
Civic Sedan Door Cap Set
Accord Sedan Door Cap Set
Del Sol Red “H” Emblems (Front & Rear)
DA6 Silver “H” Front
EK Euro “HONDA” Emblem (Black)
EK Euro “VTEC” Emblem (Black)
EF “VTEC” Decal
DA6 GS-R Emblem
DA6 “DOHC VTEC” Decal
DA6 “Integra XSi Decal”
DC5 2 Star Decal
New Driver Badges (1 Suction 1 Magnet)
Elder Driver Badges (1 Suction 1 Magnet)
CALL PM OR TEXT ME FOR PRICING
702-400-3723 Ben
702-716-3945 James
__________________
WWW.FreshImagePerformance.NET
HID kits for $70.00 shipped till the 31st of Dec
Daytime #702-517-0860 Paypal or Credit Card payment.
Aim:Flipbound18 Yahoo:freshimageperformance_fip
Myspace.com/freshimageperformance
Paypal ID Ben@freshimageperformance.net
speedracer18 is offline
Old 12-09-2009, 02:18 PM   #2
etothek
etothek's Avatar
pm'd
etothek is offline
Old 12-13-2009, 11:49 PM   #3
speedracer18
Authorized Vendor
msg back thanks you
__________________
Old 12-18-2009, 01:50 PM   #4
HapeamennyGep
HapeamennyGep's Avatar
The rear bumpers on the JDM Z12s are different than that of the USDM The front may be too, not sure....so that kit will have to be modified....
I'd rock that kit with the OEM aero front lip over that bumper....
__________________
BulletProof Servers for XRumer
HapeamennyGep is offline
Old 12-18-2009, 04:45 PM   #5
speedracer18
Authorized Vendor
What?
__________________
Old 12-21-2009, 07:46 PM   #6
jdm_sleeper
Default seats
how much for rear seat?
are these seat or can you sell just the seat covers?
thank you
George
jdm_sleeper is offline
Old 12-25-2009, 10:28 PM   #7
speedracer18
Authorized Vendor
these are the whole seats not covers
$1750.00 for rear
$1900.00 for fronts
__________________
Old 01-19-2010, 02:00 PM   #8
ApexWrangler
I'm interested in most of the emblems. Sent PM.
ApexWrangler is offline
Old 01-20-2010, 01:30 AM   #9
speedracer18
Authorized Vendor
Pm'ed done
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
