#1 |
New Member
Hey guys...
I got a 94 Integra LS B18B1 and i just can't get it to pass emissions. keeps failing on Hydrocarbons and NOx. brand new Cat and o2 sensor... any help please would be great. Thanks! |
#2 |
New Member
This is not Honda-specific, but my own general experience with HC is one of basic tune-up issues like ignition system maintainance, plugs wires, rotor, cap etc. My experience with Nox issues is more related to EGR valve clogged or sticking or the EGR passage in the intake manifold clogged.
My B18 head has an internal passage from from the exhaust port to the EGR valve mounted directly on the backside of the head near the distributor. That passage was majorly clogged in my case. On some cars (not really experienced with Honda) you can check this my applying control vacuum directly to the EGR valve at idle and the engine should stumble badly and all but die when you do. If it doesn't your passage my be clogged. A new cat solved mostly CO for me. |
#3 |
Bronze Member
try replacing the pcv valve and play with the timing.... i went to a small garage that wasnt too busy... and i got my car to pass with no cat just playing with the timing dude was cool he wasnt busy so he let me tinker with it till it passed
__________________
93' civic si b16 sir2... sold 93' civic cx.... got hit by semi..have a 94 teg now just rebuilt ls with p30 pistons and got a sir2 lsd trans... and more..... |
#4 |
New Member
Was your timing on spec when it passed or did it have to be off spec to pass emmisions?
Here they make you pass with timing spot-on.
__________________
1991 DB1 Project Car 1988 JR (Isuzu Impulse) Daily driver Order subject to change without notice |
#5 |
Bronze Member
no my timing wasnt set at base when we started.. i have p30 pistons which makes my motor 11;1 compression and i have my timing advanced as far as possible before knock.. i dont know the exact number... but yeah they only do the tail pipe sniffer here for pre obd2 car
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
