I replaced the front wheel bearings on my '88 CRX HF within the last 1000 miles. One side is now loose, in that the wheel will wobble in/out when the wheel is off the ground and you push on the top/bottom of the tire, not much but obvious movement. There is no end play on the bearing. No problem with the other side. On the loose side there is grease on the top of the tie rod below the bearing, which to me indicates overheating in the bearing.
Any thoughts on what could be wrong - bad bearing, or perhaps installed incorrectly? Not much to installation other than pressing race and bearing into place.
