Results 1 to 25 of 42
Thread: 03 accord ex blown battery fuse help!!!
    Default 03 accord ex blown battery fuse help!!!
    So I bought a 2003 Honda Accord ex 3 days ago ... today I went to go check the fuses under the hood and the fuse box was smoking come to find out the previous owners had rigged the blown battery fuse with a wire instead of replacing it . Anybody know why they would do that . Also I checked all other fuses in the car and out they were all good . But my doors wonít lock with the switch or key fob and my interior ceiling lights and seat warmers donít work !!! Help !!
    Quote Originally Posted by Lindseyk View Post
    So I bought a 2003 Honda Accord ex 3 days ago ... today I went to go check the fuses under the hood and the fuse box was smoking come to find out the previous owners had rigged the blown battery fuse with a wire instead of replacing it . Anybody know why they would do that . Also I checked all other fuses in the car and out they were all good . But my doors won�t lock with the switch or key fob and my interior ceiling lights and seat warmers don�t work !!! Help !!
    artikel bagus
    Halo anda ini web saya https://nontonvidiobokep.com semoga beruntung menyenangkan
    Huh?
    terima kasih untuk posting
    Quote Originally Posted by bokepid View Post
    artikel bagus
    artikel bagus
    terima kasih
    terima kasih
    like
    like
    terima kasih atas postingan anda
    ok
    ok
    terima kasih banyak
    terima kasih banyak
    artikel bagus
    artikel bagus
    artikel bagus
    artikel bagus
    terima kasih banyak
    terima kasih banyak
    like
    like
    artikel bagus
    artikel bagus
    like
    like
    like
    like
    like
    They either connected a set of booster cables up wrong and blew the fuse or you are dealing with a short to ground. Inspect all you wiring for any spots that it could be rubbed through on the chassis and grounding out. I would start at the battery wiring then onto the starter wiring. To tell if there is a draw on the battery leave the negative cable off and take a standard 12v test light put that inline with the probe on the wire and the clamp on the negative cable and then make sure that everything is turned off. If it lights up then you have a battery draw. You can pull the fuses 1 at a time and see if it goes out. If it does then you have isolated it to the circuit that is drawing power and can then work on that specific one to find out why. Be very wary of electrical fires though if they did that I would be mindful of it. One thing people should not be messing with is wiring, brakes, or steering on a vehicle until the know what they are doing.
    Yes I bought a new fuse it was 7 bucks ... been in there a couple days now and it’s been fine .. I think they just couldn’t find the fuse because you have to call a dealer for it . I dunno I’m just glad it’s nothing major
    ok
    Halo teman ini web saya https://downloadbokepgratis.net menonton film menyenangkan
