Thread: my Integra waste alot of gas
    Default my Integra waste alot of gas
    I need help. I have an acura integra 97. It waste a lot of gas. I change the harness. It turns off when u have the map sensor connected. When I disconnect the map sensor, the rpms are normal but it still smells alot of fuel. Please I need help. Thank you.
    02 sensor bank 1 b4 the cat, change fuel filter check injectors, plugs,cap and rotor, and drive less aggressive , that's all I can advise you on , and only use BP , Shell, and Mobil gastaions,
    Good advice to use se BP, Shell and Mobil gasstations. Helped me too
