Thread: how to remove outer driver door handle on 2000 Honda Accord
    Unhappy how to remove outer driver door handle on 2000 Honda Accord
    Does anyone have pictures on how to remove outer driver door handle on 2000 Honda Accord. Have the panel off but can not seem to get the lock loose from the door. Any help would be appreciated.
    It's described in the 94-97 Accord manual (Body section). Manual can be downloaded from this site. Should be same for your 2000 Accord.
    Question Help Please! Does anyone know how to remove a drivers outer door handle??
    Help Please! Does anyone know how to remove a drivers outer door handle for a 2000 accord sedan?? I have tried downloading the 94-97 manuals since there is nothing later for the accord model and it talks about a retainer clip that i cannot seem to find. The handle is broken from the outside so i cant get into the car. The lock cylinder seems to not come free from the door.
    Two bolts hold the handle in place. The retainer clip only holds the lock cylinder in the outer handle. Unless you have a problem w/ lock cylinder this part is not removed.
    Have your removed the two bolts and disconnected the outer handle rod?
    Autozone manual doesn't cover door handle removal. If you can't find any help, you can purchase a Helms manual from www.helminc.com.
    Reading your post it is unclear whether the door can be released from the inside door handle. If the door latch will not release, the problem is not the handle but the door latch mechanism which is stuck in locked position. This is much more difficult to resolve.
    See following link for some information, not especially helpful.
    http://www.youtube.com/watch?v=xHX6U...eature=related
    the door does release from the inside. it is the door handle on the outside that is broken.
