Thread: Charging AC in 93 Accord DX
    Default Charging AC in 93 Accord DX
    Hi everyone,
    I have the hoses/gauges to charge the ac, but I've never done it. If anyone has any experience with this or knows of a site I can see where to connect the hoses, I'll buy a can of freon and give it a go. Thanks!
    There's a bit more to it than just connecting the hoses.
    Is system empty or just low on charge? Procedure is different for each.
    A good site to get instructions on retrofitting and charging is ackits.com.
    If you have retrofitted, you will need a vacuum pump and you should have replaced receiver/drier also. A bad retrofit can damage your compressor and contaminate the system w/ compressor wear particles. A good retrofit will work well in your Accord, but it must be done correctly.
    Default Thanks...
    It's empty and probably has a leak, because if I charge it in the beginning of summer, it's out by winter. I appreciate the information.
    Following is suggested to achieve long lasting AC performance.
    1) Remove evaporator and replace all orings on expansion valve and temperature feedback bulb. These leak w/ age and may be reason for your loss of charge. A new expansion valve adjusted for R134a can be installed, but many go w/ old expansion valve.
    2) Examine compressor closely. Any evidence of shaft seal leak. If yes, then a rebuilt or used compressor is indicated. You can also replace the shaft seal (ackits has them). A bit tricky to install the shaft seal. Let me know if you need to do this and I'll provide some guidance. Remove and/or drain all oil from compressor. Add 3-4 oz of new lubricant (double end capped PAG or ester oil- Ackits has both).
    3) Replace all AC system connection orings. Use Nylog oring conditioner/lubricant to insure good seals.
    4) Air blast condensor to remove old oil; Pressurize w/ finger over exit, pop-release once pressurized to remove oil. Repeat quite a few times 20-30 to get as much oil as possible out of system.
    5) Replace old AC low and high pressure connection points w/ R134a retrofit adapters; good quality (not interdynamics!).
    6) Last step before closing system is to replace the receiver/drier. Note, remaining new lubricant must be installed in condensor and reeiver/drier; about 4 oz for a total of 8 oz.
    7) Use vacuum pump (rent, ebay, or harbor freight) to pull a vacuum through your AC manifold/gauge set. Close valves and monitor vacuum level for 30 mins. It shouldn't drop more the 2-3 in-hg and stablize.
    8) If vacuum level holds, recharge w/ 24-28 oz (two cans of R134a). Check recharge instructions on ackits.com for detailed guidance.
    Note, before starting I would suggest reading a book on automotive AC systems and repair; Mastercool or Haynes have decent books.
    Above is not a trivial job, but not hard on 90-93 Accord. Find a download manual from this vintage to guide your work. Do it right and probably last time you'll touch AC system in your Accord.
