Thread: B18b LS automatic into D15 DX automatic EG.
    Default B18b LS automatic into D15 DX automatic EG.
    Well, people, I've already been searching and posted about swapping my B18b and 5 speed into my automatic EG hatch, but I'm running out of time and might not have enough money, so I'm considering saving the 5 speed swap for when I have more time and money and going with the B18 automatic tranny that I have, instead.
    The B18b motor was recently pulled from an EG, so it's ready to drop in.
    I just need some guidance about putting the LS automatic tranny into my DX automatic EG.
    I will continue to research, but any HELP, INFO and LINKS would be greatly appreciated!
    PLEASE, keep comments about using a "crappy automatic" to yourself. It's what I have, RIGHT NOW and may be all I can afford to do.
    Here's what I already have.....
    My car-
    -1993 Civic DX hatch that came with an automatic and a/c.
    Motor-
    -1999 Integra LS B18b motor, complete and freshly rebuilt
    -Motor was recently pulled from an EG hatch (but, that EG had a 5 speed, originally), so everything that needed to be done to it or it's attached components has been done.
    Transmission-
    - 1995 LS automatic
    Also-
    -I also have a wrecked 1995 Acura Integra LS automatic, complete with engine, trans, a/c, axles, ECU, etc. that I can pull any parts I need from.
    Please help!
    I'm out of work and broke and need this car running and reliable, in about two weeks, or I'm going to miss out on a great job opportunity!
    Any little bit you can offer will be GREATLY appreciated!
    Thank you, in advance, for your time and help!
    Quote Originally Posted by Rsporty View Post
    My car-
    Motor-
    Transmission-
    - 1995 LS automatic
    Also-
    Please help!
    As confusing as it may sound, the 92-95 civic / 94-01 integra passenger side mount (transmission mount) for MANUAL is interchangeable, but the AUTOMATIC is different! ( You can not use an automatic D series transmission mount in a DC2 chassis / You cannot use a B series automatic transmission mount in an EG chassis. You will see on these pages that they are different mounts also for when installing a manual trans in an automatic EG vs. DC2 integra
    http://www.hamotorsports.com/40121mount.html
    http://www.hamotorsports.com/49520mount.html
    So, in other words, you are going to run into some problems when trying to bolt the integra automatic transmission in place. The passenger side mounts aren't going to fit.
    FYI: I have not physically attempted this swap myself as this would be rather unique. This is all information that I have figured out to try to help you just by comparing mounts.
    www.HAMotorsports.com 209.324.9880 - Your Honda Engine Management Specialists!
    Custom built chipped Honda / Acura computer systems! Hondata, Neptune, Crome, Jumper Harnesses, Chipping kits, and more!
    Nothing runs a Honda engine better than a Honda ECU!
    Problem solved.
    A local shop is gonna let me use a bay and engine lift and help me with the swaps, for what I can afford.
