Thread: Acura RSX heater problem
    Default Acura RSX heater problem
    Hi folks,
    my heater is not working for an Acura Rsx 2004 and apparently the problem is the air distribution box gears are binding up so i am not receiving heat. The techinician had to set it to heat manually and it worked fine for a month then it suddenly stopped again. is there a way i can do the same by setting the heater control valve manually, and how so? how can i gain access to it?
    download the manual from the manuals section and it will tell you how to get to the flap
    本田1991 Acura Integra H22A-LSD本田
    ^Click For Info On Car^
    VTEC is NOT "V-tec", "V-TEC", "V-tech", "V-TECH", "VTECH", "V-TEK", "vtech", "vtec", "vortech", "Vtec", or "Vtech". It's CAPITAL VTEC.
    No dashes, no lower case, no extra letters, not anything other than the correct and only spelling of VTEC. Period.
    Default AIR MIX CONTROL MOTOR
    anybody know how to fix the air mix control motor on acura rsx? or easy steps to remove it from under the dashboard.
    i am not getting any heat because the motor is binding up, i have already opened up the heater valve cable arm to fully open but still not getting heat. there must be a proper procedure (or steps) to do this manually without having to remove the air mix control. i know because the technicians did it before they just wouldn't tell me how.
    Powered By Hopes & Dreams B18C5er's Avatar
    Mar 2002
    Toronto ON, Canada
    5,977
    You're better off looking at like Honda Tech for an answer to this, or even ClubRSX. There are a lot more technical people on those board.
    Good luck.
    try looking under the dash from the driver side and moving the temp control from cold to hot. You should see a white lever trying to move under there. Move that manually and see if that helps.
    #5 is your air mixture lever
    Quote Originally Posted by B18C5er View Post
    Good luck.
    ClubRSX is full of know it all assholes.
    2009 Nissan Rogue SL AWD (Marie) - for transport
    2003 Honda S2000 (Stella) - for fun
