Thread: 96 accord lx window schematic please help!!!!
    Default 96 accord lx window schematic please help!!!!
    can anyone please send me a 1996 accord lx wiring schematic?i need the driver's(master switch) diagram so i can jumper the wires to get the window up for a friend.someone PLEASE help me!!!!!!!!!!!!
    simple, take off the door panel,
    unplug the power window motor, and supply 12 volts, if the window goes down, swap positive + negative, and the window will go up.
    if its a 3 pin connector, then go from pin 1/2 and 2/3
    Thumbs up jump the master switch
    If you are still having this problem, jump these two leads at the driver's door master switch:
    green/white - most forward inboard lead with the switch in normal orientation
    red/blue - fourth position back
    Due to the switch having some normally closed contacts, there are a couple of caveats:
    The switch must be plugged in, which means that you will have to jump the contacts from the wiring harness side of the plug.
    You have to hold the driver's window switch in the up position while you jump the terminals.
    If you make the jump without the switch in the up position, you will blow the fuse for that window, located under the hood. So, remember the correct order:
    1. Push window switch up and hold.
    2. Jump green/white to red/blue until the window is all the way up.
    3. Remove jump wire.
    4. Window switch may be released.
    Still, a heck of a lot easier than taking the door panel apart.
    Should work on 94, 95, 96, and 97 4-door models.
